HI All,
I've just been trying to locate the VIN plate but cannot find it....
Can anyone tell me where this would normally be found, yep, I've checked under the bonnet and cannot see it there.
The alternative is can anyone tell me the kerbweight of a 1998 2.2DT Grand Espace
Adrian
the vin plate is in 3 locations inside drivers door on pillar ,lift bonnet under windscreen in the center and half way down on right hand side of engine hope this helps
I weighed my Grand Espace on a weighbridge the other day and it was 1840kg there was about 1/4 tank of diesel.
Just checked my handbook though and it says 1670kg but it doesnt state Grand or not
Hope this gives you a rough idea
HI All,
Adrian
Hi my vin No is on my windscreen on the bottom but my Espace is 2002 and the weight of your car is 1627kg i hope this helps Donald
Re.
Hi All,
Many thanks for the responses.
We're about to start towing a 1400kg caravan so wanted to keep to approx 85% of kerbweight.
Thanks Again
Adrian
