Is anyone breaking a LAGII?
If so I require a Tyre Pressure Receiver unit(Located on the under side of the car about halfway down near the braked pipes)"thanks lagdti"
And the loom that is attached or the connector and a foot af cable.
Cheers:
Anybodytumbleweed:
Tyre pressure receiver.
You were looking for a pressure sensor receiver. When you lost yours did you suffer any problems with your stereo or Multi-function display or any other symptoms?
Cheers
Quiny-g
Yes.
Stereo did not function-Replaced the 10amp fuse under the ash tray-this fixed that probem.
The eletric windows would only wind up or down an inch at a time.Reset windows by winding down fully remove keycard instert keycard and wind up fully remove key card.
Dash displayed Sensor fault in big amber writing on multi display and the graphic by the clock had all 4 wheels missing.
Took vehicle to local renalt dealer -turned off TPS system for £38inc vat.
Hope this helps
I've got one coming from ebay already from someone who's in the link above, Cheers fellas.
I just wanted to check that what doesn't work is solely to do with the receiver being pulled off.
I was worried this would cost a fortune to sort out.
Cheers
Q
