Hi all,
I have a problem with my Megane. Basically I am finding water, a good amount, exactly under the speaker where you can place a bottle. There is no sign of water on the floor.
Did anyone ever had this problem before...? The water is brownish... Other then that, its fine.
Thanks.
Check the drain holes in the bottom of the door. You will also need to remove the door liner to check that all the polythene seal liner is in place.
All car doors let in a small amount of rain water - hence they have drains along the bottom.
