Hi, I have just done an oil change on my girlfriends 1998 renault megane scenic and when I looked underneath to see if any oil was dripping out I noticed something leaking out of her exhast pipe about 1/2 to 3/4 of the way along the pipe, Its obvious she needs a new exhaust fitted but can anyone tell me if its usual for liquid to come out of it?
Lee
It's perfectly normal for water (or condensation) to come out of the exhaust pipe as it's a by product of the chemical reaction that happens inside the catalytic converter.It is particularly noticeable if the car isn't driven very hard or used for just short journeys.
Have a carefull look at the exhaust as it might just be a joint leaking slightly rather than a sign that the exhaust is faulty.
Hi, thanks for responding, the water does seem to be coming out of a joint there is a baracket of some kind right where the leak is. I guess I had better get the car jacked up!!
Tourerman
Some cars actually have a drain hole in the exhaust system to drain water so it will not internally rot.
