For renault car(not van) owners with 5 bolt wheels and their car is later than 2008 and who are looking for replacement/aftermarket wheels or a different style.
If your standard car wheel diameter is 15 in or greater you can probably fit up to 20" wheels.
All wheels which fit these cars will also match your wheelbolt pcd diameter.
nb the boresize,hole in the wheel may not match or the wheel offset (ET), but you can check those yourself and get adapters if needed.
Daewoo: Leganza
Honda: Accord / Civic / CRV / FRV / HRV / Prelude / Shuttle / Stream
Hyundai: Coupe / Santa Fe / Sonata / Trajet / Tucson
Kia: Carnival / Opirus / Sportage
Landrover: Freeloader?..should that be Freelander
Lexus: All
Mazda: 3 / 323 V6 / 5 / 6 / 626 / MPV / MX-5 / MX-6 / Premacy / RX-8 / Tribute
Mitsubishi: Grandis / Lancer / EVO V/VI/VII/VIII / Outlander / Pinin
Nissan: Almero Tino / Maxima / Primera / Murano / X-Trail / Skyline
Suzuki: Grand Vitara JT
Toyota: Avensis / Camry / Corrola Verso / MR- / Picnic / Rav 4 / Supra
Vauxhall astras after 2009 have a very similar pcd 115mm.
The renault one is 114.3 mm.. so you could probably get those to fit with "wobble bolts" and spigot rings.
Then there are these.. :
The tyres are no use, unless you have an suv, nissan juke or similar but great posing potential ;)
Oh rim protector tyres would be a must! and a large rotweiller in the back seat to prevent people breathing on the rims.
http://www.ebay.co.uk/itm/4-BK797-20-Blaze-Alloy-Wheels-Worn-Tyres-Nissan-Murano-5x114-275-45-20-2754520-/200839642363?pt=UK_CarParts_Acc_Wheels_tyres_Rims_Car_Wheels_ET&hash=item2ec2f9bcfb
Banned
The new SUV model which has a six-speed automatic transmission has been named as Hyundai Santa Fe AT and is also powered by the same 2.2L CRDI engine as its other siblings.Hyundai Motors has offered this version at a decent price tag and Hyundai Santa Fe price in India is Rs 24.36 lac. The exterior dimensions of Hyundai Santa Fe are as follows: Length- 4,660 mm, Width - 1,890 mm and Height - 1,760 mm. It has a wider wheelbase of 2700 mm and minimum turning radius - 5.4 meter.
Hi coup mate, the cars written in red have wheels that would be a straight swap to megane iii 2010, is that correct? Do Mercedes wheels fit? I'm sure there's a vid on YouTube with a white megane with amg alloys, Cheers
