where is EGR on a renault espase R-reg 98..(97/98).2.2 td
(not dci.)
done alot of reading on here about EGR.
mine espace.after car gets to running temp.its starts to judder if i try to go a faster.low power on hills.
engine sounds ok...change :fuel/air filter.fuel cleaner.as i thoght is was fuel starvation.until i found it use more fuel.(poor miles per liter)
only had this about 3 weeks.
I'd also be interested in finding out where the EGR valve is... I don't even know what one looks like :(
Question ... do the Renault TD engines have an EGR valve?
I thought it was just the later dCi engines that the valve, or the very late 2000> TD engines.
:confused:
:confused:
You are right!! thats why i cant find it,(Many thanks) so I have a different problem. when pulling a way sometime the is a hesitation before it pickes up and covers the cars behind in black smoke. any clues?? I guess I should start a new post.
