My mates 98 Megane 1.6 Auto has a ABS problem- the ABS warning light is constantly on and the abs is snatching on the nsf.
Where is the ABS ECU located as I need to test the wiring and sensors to trace the fault as strangely Autodata 2006 doesn't show where the ECU is (unless its part of the hydraulic modulator in front of the osf wheel) it should have a connector like this
there's a ECU behind the NSF Headlight and one on the OS inner wing above the ABS pump but I presume they are for Engine Management and auto box as the pin out is different to that of the ABS ECU
As I was after the most replies as i am fixing this car this evening and wasn't sure if its a chassis or electronics question :confused:
