i have just purchased a laguna II 1.6 16v 2001.
i have a problem with idling when cold and i would like to clean the idle valve first, could someone please tell me exactly where it is located?
Welcome to the forums Paul.
Please feel free to join in where and when you can and enjoy the community we have built up here.
By and large our members are a friendly bunch and quite knowledgable too.
The open forums are free for all but please take the time to consider becoming a subsribed member with all the extras that entails.
For just £1.50 month/ £12 year you get....
Access to the Arcade and the many games within.
The ability to use the forum PM system
A lovely red "supporter" badge under your name.
Club offers...recoup your subsciption fee easily with supporter only offers.
Signatures..Add your own signature to your posts.
Avatars..Use our standard Avatars or use your own.
Gallery...Post your pics
as to your idle prob...I will move this thread to the "Engines" forum where you may get more help.
That engine does not have an "idle control" valve fitted. It uses a motorised throttle body instead to adjust idle..
The body is a common failure on this engine and is not repairable.. A new body is available at around £250 fitted including ECU programming..
Or you could remove the body and clean the Plenum/butterfly which may solve your idle problem, as the butterfly does not completly close so allowing air to passby.. Oil residue builds up and starves the engine of air at idle.
