Thanks madnoel , when you take the electrical connection off does this mean i have to reset the on board computer??? And does the stop valve have a gasket on it???
thanks Eggsy
Hi Eggsy the stop valve has a rubber sealing ring and just make sure the ignition is off and you can disconnect the conector to the EGR valve - when making the joints back up I gave them a smear of anti-seize compound just in case i need to clean it again sometime - carburettor cleaner and a small wire brush is best for cleaning. The EGR valave has a metal compression gasket - but I reused it and it seems to be OK:)
