I have a megane scenic 1998 R reg .I want to replace the cassette player with a CD player . Has anyone any advice as to which model i should be looking to replace it with . I know it will have to be a renault so that i can use the steering wheel controls.PLEASE HELP!!!!!!!!!!!!
Hi joanne05
Can be confusing choosing the correct model but two things to look for, firstly as you Scenic is pre 2000 it will have a tuner list with a curved front panel and secondly the connections at the back will have the black connector for the display.
Have a look at this thread :-
http://www.renaultforums.co.uk/electronics/17971-compatible-radio-my-scenic.html
If you need a direct swap with no changes to display connector a Tuner list pre 2000 with the curved front is the one.
(Don't forget to get the code)
Hope this helps.
If you just want to be able to play CDs, then you might want to consider keeping the existing stereo and adding a CD changer.
