Hi Guys,
I have a 2006 Scenic that today started to misfire and has a "check emmisions" light on. I suspected a coil so removed the electrical lead from each in turn, the first 3 cause the engine to stall, the fourth causes a noticeable roughness to the engine but it doesn't stall. Should removing the lead from a faulty coil show no change in idle? Or is it possible that it's giving a spEk but not a great spark?
Xabi
Xabi
