Can you please update this thread when you have tried it? I want to read engine management information, can this also be used to reset engine management errors etc?99% are for cars from 2001 on there was one if i can find it that covered cars from 96 on including renault
i ordered this for programming keys but it also does fault codes and meant to work on a scenic from 98 on it still has not turned up yet so cannot confirm if it works on my 98 scenic
http://www.dinodirect.com/sbb-key-programmer-v32-immobiliser-currency-GBP.html
Ron
once i get it and test it on 98 on cars i will update this thread it can take upto 3 weeks to arriveCan you please update this thread when you have tried it? I want to read engine management information, can this also be used to reset engine management errors etc?
are ELM327 for 1991 0n for uk and europe carsELM327 from ebay. its laptop, you can use hundreds of programs with it and its super cheap
Bear in mind its only for EOBD system and will NOT cover the airbag, ABS, AT etc
if you go direct you can get it down to £101 but some outlets charge alot for postage like this onePre 2001 Renaults with petrol engines aren't OBD compliant (2004 for diesels) as already suggested a Renault Can Clip should do what you need though they aren't particularly cheap and are all generally Chinese clonesand work on a PC http://cgi.ebay.co.uk/Renault-Can-Clip-Diagnostic-Interface-Latest-version-UK-/110694080935?pt=UK_Diagnostic_Tools_Equipment&hash=item19c5e1a1a7![]()
