have the oppertunity to get the above cd/mp3 player, but i want the steering controls to still work. will a straight swap for this stereo still let me use them or would i need aditional wiring. on the box it says 'Exclusive for Renault' and says 'operates directly with steering controls' but then so do a lot of stereos if you buy the extra cables lol
cheers in advance
Hi ClioScenic,
As far as I am aware it is a straight swap if your original unit fitted was an " update list " head unit thus retaining all the controls, I know it definitely does on a Megane II & Scenic II that had the update list head units fitted originally.
What are you fitting it to a Clio or Scenic ?
Ottoman
it would be fitted to a w reg clio. it currently has a tape player in there and that does work via steering controls
The stalk controls/display will not work unless it was a " Update list " head unit fitted originally yours I think is to old to be an update list headunit, The Sony Gt30rn will still work but no stalk controls/display, Also you would need to buy a fascia surround for the new headunit as well £5 from Renault or redily available in most radio outlets and Ebay..
Adaptor leads are available but not sure which one you would require for your model of Clio.
Ottoman .
how do u find out if its an update list one?
ohhh........ just noticed you are a rangers man lol
think you might give us a run for our money next season
best man uve had for last decade walter smith
Hi heres hoping with super Ally on board as well.
It should say on the lower right at the front of your head unit.
Ottoman
