what will i do,the front passenger regulator is jammed.The cable has begun to fray,i have cut the loose bits off and it works for a week then jams again,eventually there will be no cable left,can the cable be replaced ,or do i have to replace the regulator,thanks:confused:
I believe you have to relace the whole regulator.
You should find them on Ebay for considerably less than Renalt asks for them.
Have a search of the Forums under " regulators " quite a bit of info available for sourcing and fitting them
Ottoman
