Ive had my first car , a Clio Mk 2 for about a month. When I got it the washer didnt work so I got a replacement from the scrapyard. I put it back in it works, but how do you seal it ? All the water pours out as soon as I fill it. There doesnt seem to be a rubber washer or anything to seal it.
Hi i would of thought that there should be a rubber seal you can use instant rubber seal you can buy it in a tube from Halfords but you will need to leave it to cure for a day or two before you fill back up with water i hope this helps you
RIP 31-12-2008
Hi johnt and welcome to Renault Forums, is this the actual washer motor you've changed over or the reservoir bottle? If it's the motor get some aquarium sealer from a pet shop and give a good lashing with this.
Regards Leroy
Clio washer prob
Yeh there should be a fairly thick rubber washer - and when in position its a good tight fit -smear a drop of dish washing liquid on it and it should locate easily. Don't waste your money on the aquarium sealant - it dearer than the washer which costs about £1-25. Additionally aquarium sealer is not frost resistant (never heard of a fish tank used for keeping penguins) If the bottle is cracked the sealer would act only as a temporary repair. Remember most washer motors fail either through frost, dirt or owners using washing up liqiud as a screenwash additive - that's why it's best to use the proper stuff. My local motor factors sells it for a fiver a gallon (lasts me for years) - much cheaper then than all the hassle.
