Hi all,
i have just changed the air filter/antifreeze on my recently purchased Scenic...
coolant looked as if it hadnt been changed for ages!!!
also bought a new thermostat from EuroCarparts....
Air filter changed, no probs...
Changed the stat then probs kicked in...
Noticed that it appeared small than the one i took out, however when all was re-fitted everything looked fine.
Then i found the stat housing was leaking....
took out the new stat and then measured it with the old one..
old stat measured 5cm diameter
new stat was 4.6cm diameter..
Had to re-fit old stat for now.... but just so fellow Scenic members are aware, here is the part number from EuroCarparts to avoid !!
209 74 5081
Shall be returning item tomorrow and will be contacting customer services...
This is 2nd time i have had stuff from them thats is incorrect.
Last time was a wrong window mechanism for drivers window. They ordered it in special, then had to re-order it agin from Wembley, (i'm in Swindon)...
It was still wrong...!!!
Finally found a place in Stoke via web, rang them, they double checked the fittings for me whilst on the fone and hey preston i got the right part and cheaper than Europart too !!
Rgds
Paul
209 74 5081
Rgds
Paul
