Hi all
This is my first post here, I joined some time ago but I've been lurking.;)
It seems like a helpful place here, so, I have a quick question,
I've got a Scenic RXE auto registered in 2000 fitted with aircon.
could someone tell me the minimum temperature I should get from the vents in recirculate mode with aircon on and temp dial at cold.
cheers
Roy
ps
just to save all the questions about my nickname it's because I am part of a cat rehoming charity.
you can see it at The Country Cat Shelter (CCS)
hi and welcome
i think it should be 16degrees and below
regards
nthesx
Hello & Welcome to the Forums Cathouse.
If you feel the Aircon is not working as it should a regass would probably help I would go to a independant aircon specialist rather than a Renault garage as it will be cheaper.
But I have found in the Scenic the aircon does struggle at times.
Ottoman
Hi and thanks for the welcome.
I assume my aircon must be O.K, I am getting 5.2C out of mine:d
The reason I asked is because in my previous car (a ford scorpio) I was getting 2C on low.
I'll stop worrying then :rolleyes:
cheers
Roy
