'04 Electrical Issues*fixed*
3.3K views 9 replies 5 participants last post by  ottoman
#1 · (Edited)
Hi there,
Several electrical issues have just appeared on this Megane I'm just wondering if they could all be connected somehow...
AC button stopped working
Rear window heater stopped working
Stereo no longer switches off on engine off \ key out
Wing mirrors no longer function correctly from the driver switch i.e. when engaged they rotate upwards as far as possible
Cigarette lighter not working (non smoker :) )
Windscreen washer pump appears to not be working.
The only thing I noticed was that a 5p had gotten stuck in the cigarette lighter socket and I'm guessing this may have done some damage. Is there anyway of checking the fuse that controls this to see if it needs replaced ?
Cheers,
Mully
#5 · (Edited)
All I can suggest is if its not were it says in the manual extract each fuse one at a time to check it. Hold the fuse up to the light and if the bit in the centre is missing its blown. Be aware one will be for the radio and you'll need the code if you extract that one for any length of time. The multifunction controller can cause problems too on some Renault models.
In the past I've had to disconnect the battery for 15 minutes on my Peugeot as the radio would not switch off and that sorted out the problem. It could work for you, it could make it worse but I doubt it.
Len
#6 ·
Hi, thanks but I made that mistake already!! I am baffled as I am pretty sure I pulled them all (the ones in the glovebox anyway) and they all look OK. They are not exactly easy to get out unless you have the hands of a 5 year old....I was hoping this was an easy known fault but I guess a call to Renault may in order..?
#9 ·
Hi there,
I got mine sorted at the weekend it was a blue 15amp fuse near the top in the middle.
I remember it was marked as being for music (and something else), but when it blew it seemed to stop the cigarette lighter / AC / autostereo & fan cut off on door open and the rear window heater.
I just replaced it with one of the spares on the drop down panel.
Hope this helps !!
Mully
