Clock Backlight On Espace
2.5K views 5 replies 4 participants last post by  masterofinsanity
#1 ·
Hi, the clock on my M reg espace has gone off, does anyone know if it is a bulb behind the clock of part of the clock itself, and how do you get the bugger out?cheers!!
#5 ·
Hello master of insanity ... to be honest I cant remember if its a bulb or not, but to remove the clock (if its roof mounted), you have to remove the sunroof switch or blanking plate and under that there is a torx head screw ... remove that and the console slides forward, allowing the harness to be disconnected, then you will see the clock assembly, I'm sure it just unclips.
If your clock is in the centre console along side the switches then it pulls out ... push up slightly then pull forward.
Hope it helps :)
