Headlight and wiper stalks not working *** Solved ***
11K views 13 replies 6 participants last post by  rachiehow79
#1 ·
I have an interesting problem on my 2011 clio. Suddenly the headlight stalk (sidelights, headlights, fog lights) is not working and the main beam is perminently on - however, the indicators still work. At the same time, the wiper stalk has stopped working (intermittent, contant, fast, plus rear window) - however the washer + wipe still works if I pull the stalk.
So, logic dictates that both stalks cannot have failed at the same time so I'm guessing the problem is electrical rather than physical failure of the switches.
Anyone come across something similar? Any pointers on where to start would be greatly appreciated... Thanks
Discussion starter · #5 ·
Many thanks for the advice guys, I didn't realise the light switch slaved off the wiper - that would give an expanation for the symptoms (I'm still hoping that it isn't the UCH).
I'll start with looking for obvious wiring problems then get my nose on the job ;). I'll let you know how it goes...
Discussion starter · #10 ·
Here is an update: I managed to get a replacement full switching unit from a local vehicle breakers (included both stalks and the steering wheel mounting). I took both stalk units off this and fitted them. Sucess!! Lights and wipers working once more!
Interestingly, I completely stripped down the original light stalk unit and found a broken wire on the ultra low current connector within the unit. It may be responsible or not - but at least it's all fixed now.
Many thanks for all the help and advice! (y):D
