Hi Kevin and Welcome
What engine? 1.6 petrol?
Is the fault there always or only wet weather and could water be getting into the No. 1 spark plug well leaving brownish sputter marks on the nose of the coil?
Are you using a code reader and what faults are you getting. Are there messages on the dash?
Have you tried cleaning the crank sensor?
Was any work done on the intake manifold that could have left an air leak?
What colour is the No. 1 spark plug compared to the rest?
The next steps would be to swap the No. 1 injector with another and see if the misfire moves and then perhaps a compression test on the No. 1 cylinder.
