Here is a weird one.
2012 2.0 Dci Espace 150 hoss power.
Runs fine. no error codes or warning lights.
Did a regen on the road last week logging data.
50 MPH 3rd gear. Regen comleted fine down to 0 grms of soot.
Looked at data afterwards of the run and noticed at times the pressure upstream of turbine went up to 4.5 BAR.
I understand upper limit should be 1.5 BAR max including atmospheric pressure.
Checked with Clip and Autel MaxiCom.
In the workshop at tickover pressure is around 1.15 BAR.
Just what I would expect as with ignition on reading starts at atmospheric pressure.
Pull the revs up to 4500 and pressure goes up to around 4 BAR.
DPF pressure is fine never going over 0.2 BAR.
Its pointing to a blocked cat.
What I cant understand is why car goes so well, no warning lights or codes.
Sensor appears to read ok at tickover and just small throttle inputs.
Any ideas?
Any ideas?
