21 - 40 of 55 Posts
Discussion starter · #21 ·
What I do see in the cold start video is the appearance of a possible engine temperature related issue - read EGR mechanically not sound/dirty/stuck or coolant temp sensor funky or MAF/Map issue or fuel pump modulation
[/QUOTE]
By that you mean when it sounded like the engine is going to stall?
Could that be fuel filter?
Could fuel filter also be related with sometimes car being jerky and seems like it is loosing power during driving?
These things you mentioned above would Clip recognize it only on the cold start, while the engine is acting up?
Discussion starter · #22 ·
Finally I figured out how to post the audio files. Pls take listen this is during driving
Thanks guys for the quick reply. I mentioned before the noise is not there when the engine is idling or if I rev it while in neutral. It appears while you shift in the first and start driving, reverse and all the way up to third gear. But like i mentioned it is the same as the Nissan on the video.That is why I wanted to upload the audio files of the noise while driving. But it says it is not the file doesn't have an allowed extension. I tried with mp3,m4a and was files and nothing works.
I used a regular attachment icon on the bottom. Is there anyother way of uploading it?
I might end up at the mechanic on Friday, would the EGR or MAF issue be visible on Clip? Also if those would be an issue wouldn't there be any warning light popping on on the dashboard?
Sorry was off sorting power issues here so only get back here now.
Word of caution re CLIP and expectations of the info it supplies:
Clip or any other Renault speaking scanner will not necessarily indicate/identify a "problem" by telling you about it using words to understand - CLIP et-al is basically ONLY following the logic the Renault engineers programmed into the ECU to generate complaints. Example - if a specific parameters value currently measured on the engine falls within the expected allowable RANGE of values it will not complain. Complaints can be generated when eg the value of a parameter falls within the expected range BUT the current value of another parameter at the same time is such that the ECU is made to believe the 2 values in combination is not a possible state .................. and its here the problem with the scanners/CLIP lies - not every conceivable suspect state/combination is programmed into the ECU so it's not possible to necessarily generate a warning for EVERY operational state on the engine - THIS is the most important thing to get your head around - there may be something "wrong" and its possible CLIP will not or can not tell you anything about it.
This is where a logical and trained technician that understands all intricate parameter value interactions get to shine - he needs to look at the logged data values of all the engine parameters at the time of the engine's supposed misbehaviour and see what are suspect parameter value combinations....................... hence my suggestion to get a proper Renault speaking scanner and log ALL engine parameters for a typical trip where you experience your issues
You can be sure of this though - throughout development time the engineers have made sure engine destroying parameter value combinations got built into the ECU and warnings will be generated for those - both on the dash of the vehicle AND in CLIP .................. so if there are no warnings on either the dash or CLIP chances are the issue you experience may be a drivability issue to be traced and addressed by the mentioned technician - more often than not its here that brands/engines get a bad reputation because of incompetent/clueless humans.
Sorry - any component like the AGR/MAF/DMF/whatever is well documented and a search on the forum and the NET using those terms will explain the basic operation of those - the more intricate details require volumes of text and I just don't have the time to detail it all on a forum like this - most of these items are too complicated to point a finger at by JUST looking at the vehicle with CLIP and not seeing any complaints - you need intelligent and competent human intervention from somebody that understands this particular post's implications and that will not approach the issue from a dealer's standpoint only
Your links still aren't working btw
The Nissan noise, is there any physical vibration inside the car through the pedals or gearbox? Does it happen while the clutch is being released?
Discussion starter · #25 ·
LvR, thanks for the explanation and patience. I just got to excited with all the info.
I'll take some time today and do some digging arround.
Here is another chance for the audio files. Hope it works. Please use the head phones for it will be easier to hear.
You are really taking things slow with those 3 clips, and what I only think I can hear is basically DMF noise :unsure: ............... I would start there
Discussion starter · #28 ·
No, there is absolutely no vibration i could feel inside on the pedals, also no slipping clutch, I would feel it. I have posted audios now, hope it works this time. If I get an appointment with the mechanic tomorrow ill have him check the EGR(since I noticed that after a cold start up some 3min into driving there is a fuel smell coming into the cabine) and do the diagnosis.
One thing I did notice, if I start driving off with the bit more gas the i can't hear the noise. It is more evident when I have a soft start up, you know not pressing to much gas. I hope I have explained it good.
😁😁😁 ur right, I am no Ken Block. It take it slow. But u are right if I add more gass I can't hear the noise
Absolutely nothing wrong with that ..................
but
Makes me point a finger at DMF as a first reaction
..............and a failed DMF will not necessarily always cause vibrations
Discussion starter · #32 ·
but
Is there a way for me to check it, is it easy access? The noise is also there in higher gears and higher revs, sometimes it quiets down arround 2k sometimes a bit higher and sometimes I don't hear it at all in higher gears. If it is DMF could it be that it calms down at certain rev range?
Without already knowing that the DMF has failed its impossible to answer specifically - in general all of your questions is quite possible with a failed DMF depending on what went wrong (broken spring, worn bearing, crack, warp etc etc etc etc) ............... and no sure and easy way to check other than physically replacing the thing if no other obvious faults are to be found
Discussion starter · #37 ·
There is no vibration that could be felt via the pedals or is there any slipping clutch feeling. But when I start driving with a bit more gas(not soft) It seems like i don't hear the noise
try a Google search on "dual mass flywheel failure symptoms" and check out some of the videos. See if anything seems familiar.
We are all guessing here.
Discussion starter · #40 ·
Any thoughts why the power drop during driving. It comes as sudden small shakes and it doesn't take power. Lately it has been more often. So far I haven't noticed a pattern but it does stop after a restart.
21 - 40 of 55 Posts
