Similarities between Megane and 19
1.9K views 2 replies 2 participants last post by  Cerberus
#1 · (Edited)
I finally managed to get the time to have a wander around my local breakers yard in search of a Megan rear door lock, today. I managed to track down the only Megane in a stock of 500 or so bashed, rusty amd mangled motors and got busy with the torx bits. And what the hell is that black goo all over the inside of the door panels-it's stuck all me ruddy tools together! Anyhoo, the lock only cost me £3-bargain!
As I was wandering back through the yard, I spied a 19 RT fitted with a set of front driving lights that looked remarkably similar to the ones fitted to my Megane RT Sport. As my passenger side driving lamp was broken, I figured it might be worth a fiver finding out if they were indeed the same. Renault had quoted 40 quid for said light and I thought, if they are the same, I will have saved myself £35.
After an hours hand to hand combat with a rusted in mounting screw, a quick modification with a 6mm drill and hey presto, the light is fitted to the Megane and working perfectly.:d
As I was sitting there having a bit of a breather during my application of brute force to the afforementioned rusty bolt, it occurred to me that there appears to be many simularities between the engine, running gear and brakes, between the 19 and the Megane.
Could any one confirm that this is indeed the case? I could do with a set of rear drums and I can get 19 drums considerably cheaper than I can get Megane drums for.:confused:
One more thing I discovered-the sunroof motor in a 19 fits a Megane too.:d
#2 ·
The Megane was really only an update to the 19...
The engines,gearboxes,subframes and suspension were carried over as were most of the other main components(for the early Meganes any how).
Obviously the bodies and interiors are different,but most of the other parts are the same.If I get chance I will do a part number comparison and any parts that match,I'll post them here.:)
