Car makers have been lowering the higher viscosity of engine oil for some years now and my opinion this has bu55er all to do with engine longevity it is in an attempt to lower the emission's.
Years back, you could often tell whether a Ford had an OHC engine or traditional push rod by the sound it made.
A machine gun rattle on acceleration was the telltale.
Notorious for cam failure they was, largely due to poor oil feed to the cams.
The feed was via a pipe that ran along the cams.
This pipe would clog.
Back then, no such thing as synthetic oils (for cars) and traditional oil would thicken as it got older.
Be a bit slack on oil changes, low quality oil or didn't clean or replace the pipe when changing oil and whoops, cam rattle.
I've also had cars that would tell me when oil was due, hydraulic tppets would start to rattle.
There is a thread in here somewhere where a guy was having turbo issues. He'd measured the oil flow through his turbo and it was well low. A concern with Renault units that rely on oil flow to cool as well as lubricate the turbo bearings.
He had 10w40 in instead of the 5w30 recommended. Changed oil and flow back to where it should be.
I think of all the little oil ways in an engine and getting oil to them and through them, cams and valves at the top end, gudgeon pins, big ends and journals and think why risk it?
It's not as though you can pop into your local scrap yard and pick up an engine to swap on Sunday any more
