21 - 40 of 42 Posts
? You can get the official update via Renault MediaNav program. Just take the info from your medianav and plug your USB into your computer and let Renault's program update your files to 9.1.3. Or maybe you know this already and that's why your trying to downgrade.
I didn't thank you.
Hi, I just updated from 5.2.8 to 9.1.3 and I noticed that the sound is lifeless ever since.
To which version do I need to downgrade in order to get the good sound quality?
8.0.5 or 7.0.5?
Okay, I'll try tonight. Also, do you know what's different technically between 8.0.5 and 9.1.3? What's causing this poor sound quality with this update?
I didn't notice any other difference other than the sound quality. 9.1.3 just tries to balance out the frequencies for songs in my opinion, I prefer to have my own control using the equalizers since I have installed an aftermarket subwoofer.
Do you think 8.0.5 is the best version for audio quality? What about 7.0.5 or others?
Quality changes from 8.0.5 Upwards. It is the same from 8.0.5 downwards. The difference I noticed between 7.0.5 and 8.0.5 was that it would reset my equalizer settings sometimes on 7.0.5, but it doesn't on 8.0.5
Thanks a lot for all these infos.
Last thing before I downgrade, I saw that when downgrading with fake 5.0.0 and upgrading to 8.0.5, two problems occurs.
First is the ITaskMng windows that pops up when the Media Nav is booting:
Second is a pop up telling that its impossible to use the navigation because of the map licence:
Can you confirm that the files provided by @NeeK in page 1 of this thread do not cause these problems?
I don't remember getting such errors using @NeeK's files
clio974 alias RGMaster3 if I don't mistake.
The problems occur in your unit because of additional software what you had installed. In original units these doesn't exist.
And the problem of not opening navigation is because license is not recognizing the map files added in various ways, not official, or even license wrong. That is normal when you install a new firmware to put original files in the right places.
I just downgraded with @NeeK files from 9.1.3. to 8.0.5. and everything went fine.
Now I have the same quality as before.
The 9.1.3. is definitely not a good update if you care about sound quality because it applies a "lifeless" filter to the audio.
Thanks to @NeeK and @mavhungu for the help provided.
Hi guys, I recently moved from a 2017 trafic to a 2021 trafic and the medianav system turns the volume down past volume 19.. what the hell is going on? My old van used to have a banging sounds system and the new one looks like the same hardware but maybe software not allowing high levels of music? Can I do the downgrade with out bricking my unit and will the reversing camera still work?
You need to find your software version. If you have the latest 9.1.3, you should downgrade to 8.0.5 which is the last version to have the natural and loud sound settings.
But I'm reading that you got the 2021 Traffic and I don't think it's the same old Media Nav like us. If it is, just downgrade. Sorry if the English is not perfect, in French.
Thank you sir, my software is 1.0.15.0 the medianav unit looks the same as my old one, I think it is the same... if I load the old software will the rear camera still work?
I'm not sure but I believe that you have the last Media Nav 3 based on the software version that you gave me. The one that we are talking about on this thread is the Media Nav 2.
Unfortunately, I don't have any knowledge about yours. Maybe someone else can help you on the thread.
Hello,
I own a Dacia Duster (2016 model) with MediaNav Evolution, firmware version 5.2.8,
and I have some questions:
1)Should I upgrade to version 8.0.5? because I read 9.1.3 has issues with the sound quality.
2)What are the differences between 5.2.8 and 8.0.5?
3)Does 8.0.5 make the interface a bit faster and more responsive?
4)Is there a version that supports video playback? AVI or MP4?
5)I also found out about Menaco, an alternative to MediaNav Evolution. Has anyone tried this? Is it as good as it claims to be?
Thank you all in advance!
You didn't look where need or you didn't ask right person. :)
Here down you have:
MN2 Upgrade to fake 5.0.0 this is first step in dowgrade.
MediaNav Evolution 7.0.5
7.0.5 - 20161102_Renault_Dacia_OS_Update
MediaNav Evolution 8.0.5
8.0.5 - 20170523_Renault_Dacia_OS_Update
Good luck and enjoy.
Dear friend!
This post is from 2020 so I have no idea if you will see this message.
But I would like to thank you immensely for your support.
I'm from Brazil, and here I tried to help even at Renault stores, I sent an email to the company... But nobody was able to help me.
I ended up finding this solution on a French forum, however, despite asking for the file, it was not granted.
And suddenly, I found this site through google and my salvation to recover my MN came up.
Thank you very much! Thank you very much! 😘
21 - 40 of 42 Posts
