Started new thread, as I was on the UCH thread before and someone advised me that I have fault with the alarm.
1st Question: Which bit is the alarm? I've removed the glove-box (which was surprisingly easy). Which bit is the alarm?
Pic:
Other questions:
Many thanks in advance for reading and for the advice.
Problems
Pic:
Other questions:
- Is it easy to remove the alarm?
- Can I fix it (dry out if water logged or reset it)?
- Or should I get a replacement?
- Is it likely that I have faults with the UCH and or ECU too? (problems listed below).
Problems
- Lots of water ingress issues. Channels blocked with debris at one point resulting in water in cavity under windscreen (and at one point water coming all over feet/petals inside car).
- Long running issues with alarm going off if the sensor is not disabled every time I leave car (pressing start 5 times).
- Recent issue with hazards on all the time. Car starts okay, and drives fine. I have to disconnect battery terminal to stop hazards flashing.
- Sometimes "card not detected"
- Sometimes (when engine running, door open, key in slot) the car keeps locking/unlocking itself over and over
- Sometimes when trying to lock (after hitting start 5 times) the hazards remain on (not flashing) and a load constant beep sounds.
- 3 out of four doors electric windows no longer work
- Large dents in both wheel arches (gender specific spacial awareness issue :d)
