Hi all, after some advice/help? Since I bought the Clio the air con has not worked. The light on the dashboard comes on but the clutch is not engaging. I have had the gas checked which is all fine and I have changed the pressure switch on the condenser. I have pulled the plug off the compressor and checked it with a meter and there is no power going to the compressor/clutch. I have checked the fuse in the car which seems fine but can find nothing online about a compressor clutch fuse or relay. I know there are several fuses/relays next to the battery but which ones do I need to check/replace???
Many Thanks, Vezrob
Many Thanks, Vezrob
