Renault Megane 1.6 rattle
Tags
megane rattle
8K views 16 replies 8 participants last post by  madnoel10
#1 ·
Hello, can anyone offer any advice on the following? Our '97 Megane has begun to rattle when started up. It then rattles occasionally, usually when we slow down or change gear, but only for the first few minutes of driving, then is fine. It sounds like it's coming from underneath so we thought it might be the exhaust but have never managed to watch it doing it. The exhaust does look like it's vibrating quite a bit, is it meant to do that? Otherwise it looks fine and we can't see anything like brackets obviously missing or loose.
Does anyone have any idea of what this might be and if it's likely to be expensive to fix?
Many thanks,
Ivy
#2 ·
Hello and welcome to the forums.
Whe you say underneath, do you mean underneath where you sit or further back. It could be a lose braket near the downpipe/cat or the baffle lates in the cat could have gone which means a new cat being fitted. Not too much of a hard job really but Cat's can vary in price depending where you go. Might not be it but mine was when I had a vibrating rattle underneath my Meg.
How many miles has the Meg done?
#3 ·
Could be the catalytic converter breaking up or the heat shield above the cat is loose. Happened twice on my Meg - 1st time it was the heat shield but eventually the cat did need replacing.
An unscrupulous exhaust centre will tell you you need a new cat if the heat shield has loosened. They'll not tell you its the heat shield of course, they'll tell you its the cat ;)
#11 ·
The Meg will linger on with an oil leak from the head gasket for ages and ages. It will eventually go bang so its up to you how long to risk it. Glad you got to the bottom of the rattle though, even if you are moving the car on :)
#12 ·
Thanks again all. It was quite funny at the garage, we could hear all the mechanics behind the door going 'you tell them!' 'No you tell them!'
We just got back from a holiday and it was OK although doesn't half honk of burning oil! We don't really use it for a lot anyway so if it goes kaput on the way too or from work, it doesn't matter too much.
#13 ·
Ha ha ha. Bet it would have been funny to watch. I hope it runs on for a while yet for you anyway. At least it isn't going to be too much of a shock when it does go.
#16 ·
cat for scrap
do u get good money over there for old cats, the precious metals in their construction brings good money out here, any old cat is worth 25 to 30 bucks for scrap, thats about 8 quid in your dough, so if your old cat needs replacing, keep the old one for scrap value, the muffler shops make a mint out of keeping the your old cat convertor, they are worth money.
#17 ·
Unless the heatshiled is badly corroded or mangled they can usually be repaired using a few additional washers and nuts, etc. I would think the cars manufacturer designed and fitted it for some good reason. Although the car may run OK without - it does help a bit to reduce cabin noise and it also may be protecting cables or pipes whch run nearby.:)
