Independent Renault Forums banner
Renault Trafic 2012 2.0dci df070 (oil dilution fault) won't go away
2 reading
55K views 32 replies 9 participants last post by  LvR
#1 ·
Hi,
So a few months ago my Trafic started flashing up with 'check injection' and 'check emisions'. I took it to the garage I use and they performed a dpf regen and faults cleared. A few weeks later the faults returned. This time they said they were stumped as they didn't believe there was anything wrong with the dpf but they had a few faults - oil dilution, one to do with glow plugs and engine management. They said I should take it to Renault and see what they think. Renault told me the dpf was wrecked and needed replacing as well as the glow plugs and that the oil dilution fault was wrong oil being used. I went back to my garage and they replaced the glow plugs (no problems there) but said they couldn't understand how the dpf would need replacing when it was far from blocked. They performed another regen to take the soot to 0g and even though it had been serviced only a couple months prior and had an oil change then, replaced the oil and filter again and managed to clear the errors.
A couple weeks later on a 40 mile trip down the motorway the 'check injection' error returned to go away 15 minutes later.... And exactly the same a couple days later on another longer journey. A few days later it came back for good and I took it back to the garage. Only fault code that now remained was the df070 oil dilution. They had then concluded that they believe it to be a ECU fault. They then sent it to a company who said they would fix it only for them to come back and say they couldn't repair that type of ECU. The garage don't believe there's anything more that they can do and have referred me back to Renault. Of which they're only going to tell me I need to change the oil and maybe need a new dpf again! At my wit's end here and not sure where to turn with this issue. I had looked at another forum that said there is 2 sensors on the dpf one before and one after to measure the pressure and if they're faulty at all it will be sending the ECU false readings. Thinking maybe it is that as I did have the fault come on and off for a couple journeys...... I don't know if my ECU is repairable at all or if it was just that particular company... Maybe I need a new one.... I don't know!!!! Any advice would be greatly appreciated as I'm losing my mind over here!
Thanks,
Abi
#2 ·
Hi AbiBuck and Welcome:)
What is happening to the oil level?
What car and engine have you got?
A possible explanation is that if the DPF keeps calling for regeneration you could end up with a lot of fuel in the sump.
Typically the sump level rises and maybe this is what triggers the oil dilution flag.
When DPFs were new some constructors sorted this with software changes.
I would be inclined to follow the sensor idea including the associated tubes.
Oh it's a 2.0 Trafic dci !
If I'm not mistaken, df070 is a crank sensor fault.
#3 ·
Me only .................
I will change the oil and see if its happier.
ITO ECU - the ECU refuses to do an (auto) dpf regen whenever there is any fault code present on the ECU - and in particular the oil dilution value. If you now go and force a regen you only screw the pooch by adding yet more fuel to the oil................. and if a forced regen is "successful" your oil dilution is still vey close to the ECU's perception of contaminated/diluted oil - next time you are on a trip and a auto regen gets triggered because its required, the ECU may start the process and then discover you have diluted oil - hence the recurring warning.
Read the whole of the thread this particular post is part of - lots of explanation there...............
#4 ·
AFAIK, diluted oil happens when regeneration is not successfully completed.
During a regen, extra fuel is squirted in to increase exhaust temperature and aid in the regen.
If the system doesn't see changes that say regen is complete, after a number of failed cycles it throws a wobbly, assuming that the added fuel has ended up in the sump.
AFAIK (and may be wrong) the system doesn't actually measure anything to do with oil, just makes an assumption.
But as Brendan says, are your oil levels increasing?
By the sound of it, everyone has concentrated on the DPF but not the sensor..
There is only one but is connected to DPF before and after, it measures differential pressure.
Common issues with these are blocked or cracked connection pipes, failure of the sensor itself seems a lot less common then may be believed, a fault shows and people swap them, it is often only the pipes.
#7 ·
Thanks folks, I've brought up the possibility of a faulty crank sensor. They garage says they have looked into that but believe that it is not for my particular van rather older or newer ones? They quoted me £100 to have this changed but said it was highly unlikely this was the issue?
I'll have a look into the oil level.
Dancingdad: I'll see if they have looked into possible blocked pipes or cracks.
When I took it back to the garage the most recent time they did say that the machine said it did a successful regen within the last 300 miles. But yea it does sound like it may possibly be failing the regens hence the fuel addition. It also worries me that because there is a fault it won't do the regen and will then build up soot and do damage... Worried to drive it until fixed now!
#9 ·
Weeks later your driving style/distances caused one or more failed regens (its required 20-200km) ................ every time the regen starts and fails the oil is contaminated more - after enough contamination enters oil the ECU simply says enough is enough.
Fail is possibly a misnomer in this case - I would say better word is not completing during your typical trips
#10 ·
Thanks LvR. I did quite a few long trips in the 2 weeks since the oil was changed. although I do have a short trip to work... but it also has never been a problem before. Seems a bit odd that it would be failing.
Maybe I'll get the oil changed again and go from there. 🤔
Anyhow I checked the oil level and it was quite high. Although I do not have anything to compare to so am not sure if it has increased.
#11 ·
Me? - I would change the oil and start a strict daily monitoring regimen.
Just so its said - leaky injectors can and do also cause exactly the same fuel dilution problems with associated higher than originally filled sump levels
If you now do change the oil I would think an immediate manual/forced regen is in order just to prevent skewing of results
#12 ·
Ok thanks for the feedback I think I'll get the oil changed and a regen and get them to have a look into the pipes and the sensors just to eliminate that as a possible issue.
I know the garage I go to has been very helpful in dealing with these issues so far and due to them changing the oil and regening it before have become stumped and concluded it to be a ECU error. I realise no one has mentioned that as being a possible issue. Do you think if I get all I have mentioned above (oil change and pipe checks etc) done and the error still remains that the ECU would then need a look at either repair/replace?
Thanks for the help ☺
#17 ·
Ah - real world progress:
When it goes to the guys, ask for and have them issue you with a log of the values of all the engine parameters they saw for a 5 minute period while the engine stood idling at their premises.
If you can post it back here you can already learn an awful lot about the ECU and the general control system health
#23 ·
Hi KEV
Thanks for the quick reply
It's been on 4 diagnostics. Snap on,delphi, bosch and the last one can't remember.
Bosch was the last one. I'm sure they do all that. Will ask on Friday but I know they inform the ecu of any work they do
Regards
Les
Don't need a scanner to clear those service/oil counters ............ gets done on the dash with the help of the buttons on the stalk.
You can check it now yourself (see owners manual on how to view when next oil service is due and how exactly to reset)
I have a feeling you need a new mechanic since imo with just about all those scanners he should have been able to motivate and stop guessing about what is going on.
If he tried and followed the contents/suggestions in this thread a regen must surely get triggered or a decent explanation/motivation must be forthcoming on the wasting of your money
I cannot believe the costs you have incurred in chasing this at all. :eek:
I would insist on a log of all engine parameters during a short trip with your engine using a proper Renault speaking scanner - the brand name of the scanner is irrelevant as long as he can produce the correct and complete information
#25 ·
Hi LVR
Point taken. It's been to 4 garages and I forgot to mention also a Renault dealership making 5. Renault scanned and forced a regen and nothing else. I tried to remove the lights myself last night but no luck. I'll try again today.
Thanks for the reply
You will not be able to clear the dash moans yourself - all you can accomplish yourself is to reset the service/oil counter - THAT action should allow an auto regen to happen IF environmental conditions are suitable and only once an auto regen has completed successfully AND the DPF has no other b.itching to do then the dash moans will clear automatically
Your dash has a builtin service indicator - what is it's value now? ................. it should be something like 15000km or 1 year
#29 ·
This problem can be caused by a dpf regeneration being carried out before resetting service reminder - the oil dilution pid should read 0% before the regeneration is done. If your oil dilution is over 10% an error is logged. This calculation is now stored in the ecu. Your dpf will continue to block up as regeneration will no longer happen . A new ecu will rectify this if installed correctly with out any of the old ecu data being transferred to the new ecu. If someone knows how to reset the ecu I am all ears.
#30 ·
It is now November 2023. The problem that you're having, or anyone now reading this is... your 'upstream turbo tube' is BLOCKED! If you look at the back of the engine, (mine being a 2018 1.6L) you will see there are two sensors'. The left hand one is what you need to remove, behind this is a rubber 90° bend that fits onto a small metal tube. get a bicycle brake cable / guitar cable / similar and push it down the metal tube. First off, you should use a hand gauge pump and when pumped it should read ZERO! IF there is any pressure, on the gun, then you have a blockage and that's your only problem! Get a battery hand drill, connect the cable to the drill and carefully push the cable into the small metal pipe, (this goes down to the vaporizer), and then remove the cable and double check, with the pressure gauge again. If it comes back with a reading of ZERO, all is cleared BUT, the small metal tube must be clear. You could then squirt some break cleaner down there. After this you need to do a DPF clean. get a foam can type of DPF cleaner then remove the tube, under the van, that comes from the sensor, there are two tubes coming from it... one goes to the back of the DPF and the other one goes to the front of the DPF... that's the one you need to pull off of the DPF then read the foam can instructions and pump it all into the DPF then run the engine and rev to about 3000 RPMs'. Clean the upstream sensor and put it all back and your van will run nice! I HOPE this helps someone today, as this is an old thread... good luck! Tom
#32 ·
Привіт тутHello everyone I have a Renault Traffic 3 1.6 engine 104 thousand mileage and at first I had problems the DPF filter was clogged I went to the service they told me to do a forced regeneration and change the oil I did that, first I did the regeneration, then I changed the oil, the regeneration was not successful, there were 9 grams of soot left and the error with the thin oil does not disappear, I delete it and it still appears And also 30 unsuccessful regenerations when I did the first regeneration then 67 grams of soot and still the regeneration was not successful the second regeneration was 26 also not successful what prevents it from doing regeneration help Please
#33 ·
Bunch of idiots telling you lies.
Regen and oil dilution are closely related - if the oil dilution is already a problem ANY regen will NEVER clear all complaints even if the DPF happens to contain ZERO soot.
MAKE SURE YOU HAVE NO EXHAUST OR ENGINE PRESSURE OR TEMPERATURE RELATED ERRORS PRESENT (EXCLUDE DPF REGEN REQUIRED MESSAGE)
Drive the engine till hot.
Change the oil and filter.
Clear the oil service indicator and confirm the ECU has this happening (oil service due distance will return to something like 15000kms or 1 year) - DO NOT CONTINUE TILL THIS STEP IS COMPLETED
Now idle the engine till forced regen pre-conditions are met (exhaust, coolant and oil temperatures).
Allow a forced regen to start and do not interfere - let it finish on it's own time and rate.
If you followed the recipe the DFP will be very close to 0 grams (NOT 0) and you will have no errors present about DPF or oil quality.
I am guessing you have not bothered to read the contents of the whole thread here, and as usual, are wasting a ton of money
