21 - 40 of 47 Posts
Discussion starter · #22 ·
Hi LvR
I hope you are well, about 4 month ago you replied to a message on a post, that I should have a scan done, I can not afford to have a scan done.
I brought the car second hand, with the battery in the car, Its a 628 and it should be a 652. The Fan has not worked since the day I got it. The battery is not that great either, that is why I was wondering if it maybe the battery thats not strong enough for the fan to run to. My Car Radio also works some days and not other day .
Please can you help
Have a Great day
I did reply to your private message yesterday too.
So this battery thing is new then - If that battery is known to be bad I would replace that first else you could/will be chasing your tail with all sorts of stupid electronic issues - have the charging system tested properly too at the same time.
Its no use saying you cannot afford a scan - read my reply to your message yesterday - the reality is you need to be methodical else you are going to spend a ton of unnecessary money anyway by guessing.
If the fan motor itself is ok then as per my reply:
1. Wiring/connectors
2. ECU
Before you do ANYTHING - you want to know for a fact that the ECU is actually issuing the FAN-ON command............... and the scanner is the only way to figure that
Discussion starter · #24 ·
LVR
I asked for your advice not for you to say
"Its no use saying you cannot afford a scan .... " The Fact if I can not and that is why I am on the Forum. If I had the cash I would have gone. I asked your advice if you may think its the battery. Rather say you do not know.
As LVR has correctly pointed out, you need a scan. You are definitely going to spend more guessing what part might be broken, than a scan would cost. You can do it yourself with the free DDT4ALL software and a £20 USB elm OBD dongle
Discussion starter · #38 ·
will have a look.
IF I forget
BUMP your post Ian .
You replied on one of the other post, the Following, same fuse box That one was for a 1.3 dci and I have a 1.9 but box and fuse lay out the same
You Said
Jun 14, 2018
Fuse 1 Heating control 80.0 A ( white fuse is number one ) I have a 30 A green fuse not sure if its right
Fuse 2 Preheating control unit 70.0 A The same
Fuse 3 Not used 30A green
Fuse 4 Heating control 80.0 A 30A green
Fuse 5 Cooling fan (60A also used) 40.0 A 60A blue
Fuse 6 Diesel fuel heater relay 20.0 A ( yellow fuse ) 20A yellow
Fuse 7 Not used
Fuse 8 Cooling fan relay ( green fuse ) green fuse in a very bad state but not fused,
Relay = fuel heater relay
Fuse 8 Cooling fan relay ( green fuse ) Is this the Radiator fan relay fuse. please see attached pic of my fuse
21 - 40 of 47 Posts
