If you are in England, Engine Management light is an Advisory,, not a fail.
As long as your emissions pass, you should be ok,,.
If your emissions do fail ,, make sure you get a read out, then you can always pop it on here, for us to see if it is just the lambda giving you an issue...
Good Luck with the MoT
