98 Espace Headlight Fuse?
1 reading
2.9K views 1 reply 2 participants last post by  dingdong2580
#1 ·
Where abouts is the fuse for the headlights? I see the ones for the main beam and the side lights but by the look of the manual are they Relays? and if so which ones?
cheers
#2 ·
Hi i know it a bit late for you but it might help someone.
Mine is a W reg (2000) Mk 3 espace
i found mine under the bonnet N/S in the fuse box to the right of the battery. look below the relays you will find 3 blade fuses, 2 blue 1 yellow. the 2 blue ones are for the dipped headlights. they are 15 amp fuses.
Hope this helps someone out there.:d
