Clio 99 (V) Cutting out while driving HELP
1 reading
7.1K views 7 replies 3 participants last post by  dmxop99
#1 ·
Hi Experts
I am struggling with a problem I have had over the last few weeks. The Clio is intermittantly cutting out when driving (car can drive 50 miles before cutting out).
I then find that the car wont start again until left for 5 mins. If I try and start it before then it tries to turn over but engine does not fire.
I have had the TDC (crank) sensor replaced and the CTS Coolant temperature sensor replaced but this has not helped. The CTS replacement seems to have improved things however.
Only thing I notice occasionally is that the reg temperature warning light may flash on and off quickly - but this does not happen very often. Engine temp guage is in the normal just under half position.
Not sure what else I can do - I hope someone can offer some assistance!
Many Thanks
Mark
#2 ·
How exactly does it cut out? Is it as you drive along or when you come to a stop/slow down for traffic lights/roundabouts/junctions etc?
I'd a problem like this in my Laguna a few years ago and it was because the breathing pipes and throttle body had become clogged up with oil/crud.
I took the pipes off and cleaned them along with the throttle body with carb cleaner and it was like a new car after and it sorted the problem, which was that there was not enough air getting into the engine to ignite the fuel so it would stall.
#3 ·
Many thanks for your reply.
It cuts out whilst driving - I was going 70mph on the motorway that last time it happened.
I have never seen it cut out whilst stopping/slowing down etc.
Does that mean it could be throttle body?
#6 ·
Many thanks for the adivce so far..
I have kept a close eye on the problem, and it cuts out just after starting up the car sometimes other times while do 70 mph.
I have the car booked into a reanult speciliast so will update you when I get some more information.
In the meantime any more advise would be good.
#8 ·
I think you might be onto something with the fuel pump. I started the car today a number of times and after a few seconds it cut out. I then listened and could hear the fuel pump primeing over and over without me doing anything.
I then turned of the ignition and turned on and heared the pump prime. Then it started priming over and over again 3-6 times (on its own). When I hear it prime the yellow "coil" and red "water temp" light flashed on and then off.
Even though it did this the car did start every time.
Hope this helps....
