Diesel 1.5dci or 1.9dci?
17K views 19 replies 7 participants last post by  bpowell555
#1 ·
Hi, after just 3 months of owning my Grand Scenic 1.6VVT I've had enough of its faults & lack of of punch & am now contemplating trading it in for a diesel.Which in your opinion is the better of the two? I know theres a 100bhp & 106 version in the 1.5 & 120bhp & 130 version of the 1.9-anyone got views on which is the better?
I'm not looking for sports car performance, just a bit of go from standstill! Also looking for a more reliable engine-so anyone who owns a diesel in this model, your opinions would be gratefully received.
#2 ·
I've never driven the 1.5dCi, but looking at the torque and power graphs for the one that they've put in the new Laguna, it looks like they've gone hell for leather to achieve that peak BHP figure, while the actual available torque throughout the rev range looks pretty disappointing. What I suspect you'll be getting is a diesel engine that drives like a 100bhp petrol engine (though lower revving.) It doesn't look to give you the benefit of high low to mid range torque (and therefore near to peak power at low RPMs.) So performance-wise, the 1.9dCi 130 would be my choice of the ones that you mention. It's got loads of torque - in fact for any given speed, it pulls a lot better in 6th than my old 2 litre petrol Lag did in 5th. Though seeing as my 55 plate 1.9 dCi 130 just ate its turbo at 70K and ended up needing a new engine, I'd hold out for the 2.0dCi, which is available in 130, 150 and 175bhp variants (depending on the model of car.)
#5 ·
Moving up from a 5 speed to a 6 speed is much like it was moving up from a 4 to a 5 (if you were on the road back in those days :)) It's just a case of getting used to using the extra gear. 6th is mainly useful for motorway cruising. On mine at least (there may be different versions of the box for different models, along with different final drive ratios) 6th is a genuine extra overdrive gear over the usual 5th, which is also still an overdrive gear. They don't appear to have closed the ratios and made 6th equivalent to 5th on a 5 speed box (I hope this is making sense.) On the Lag dCi 130 at least, the car is happy to plod along at anything from about 45mph upwards in this gear as long as you're not looking for rapid acceleration or climbing any hills. Just try not to get into the habit of going from 4th to 6th (which the car is quite happy to do.) If you ever hire a Ford Focus, you'll find yourself trying to crash it into reverse on the motorway.
#6 ·
I test drove a 1.6 Scenic and the 1.5 dCi (80) that the OH eventually bought. (both 2004 models) The 1.6 had noticeably more get-up-and-go that the 1.5 dCi. If it was for me to go hurtling around the country in, I'm sure I would get annoyed with the 'leisurely' 1.5 dCi, but as the OH is just doing local journeys with a car full of kids the 1.5 dCI is a very economical and easy to drive.
#8 · (Edited)
The 1.9 has a history of turbo failure that can not infrequently lead to engine failure. There are ways to offset this, a full service car with less than 90k for instance - renault offer an extended warranty on the turbo and consequential damage called yellow ots up to 90k or 5 years on full service cars for this very reason, as they were getting a bad rep. Or get an aftermarket warranty. Even regular oil changes will not guarantee against it if you can't guarantee what the previous owner did. :)
edit: having said all that my 2.2 turbo will probably go pop 2moro :d
#11 ·
Hi there I have a 1.9dci laguna 11 52 plate have done 103 thousand miles always made sure oil is changed regular and never gone down the motorway flat out and pulled into a service station and just switched the engine off ALWAYS allow the car to tick over for about 80 seconds I find this helps to stop turbo failure other than that good servicing should look after the motor as long as you don't abuse it, any diesel engine will last as long as it is cared for,
thats why diesel's are so good because their reliable.
#15 ·
Mk 2.2lt & the new 2lt have been know to give problems too, my current 2.2lt for one, turbo replaced at 16k odd miles. :shocking:
I had a RTDT Lag 1 from around 10k to 89k also a 2.2lt turbo, with no turbo EGR problems whatsoever.
I know for a fact the Mk2 uses a variable geometry turbo, I'd be interested to know if the Mk1 was the same, or if the later was a static geometry, if thats the correct phrase. :confused:
The way I see it, the engines are made by Renault which in both mine and my outlaws experience in the past have been extremely reliable.
The turbo's are made by Garrett who have a great name in making these items, none better imho.
The only difference from what I can see is the oil & filter change regime, the Lag 1 every 6k, the Lag 2 every 18k.
Assuming Renault have got this oil change interval correct, it makes me seriously wonder if there are issues with all variable geometry turbo's which I would guess would affect a lot more cars other than those made just by Renault.
#16 · (Edited)
hondo, do you drive like horatio?
http://www.renaultforums.co.uk/showthread.php?t=43683&page=3&highlight=turbo+cool
The 2.2dCi is variable vane/geometry (don't really know the difference) - doubt the turbo is on the old 2.2D which had much less power, and I don't think the 1.9 is either.
You're right this clogging up could cause probs. I reckon a turbo is a service item but a lot of peeps say it should last the lifetime of the engine. Well, if the engine explodes I guess that's probably the case but I don't want mine to go down in flames :d
