megane 1.5dci injector seals
16K views 20 replies 5 participants last post by  Natedawg8t6
#1 ·
Just a quick 1, im replacing the seals on the injectors. With the retaining clamps, do they go above or below the 2 little notches on the injectors? Didnt take much notice when i removed them.
Also, 1 of the injectors (number 3 from cambelt) is in solid and cant remove it - any pointers on how to remove? The others just pulled out.
Thanks.
#7 ·
Yes, this is an art form with the megane 1.5dci type of feul filter. I hand primed it, bled it then primed more (until reasonable amount of pressure on priming bulb.) Then turn ignition on and attempt to start but let clutch off or turn key back very quickly for a sec or two for about 5 times then go for the big start - it worked for me :)
Sent from my HTC One X using Tapatalk 2
#8 ·
well whoever had the car b4 me removed the hand pump, but ive been to buy 1, fitted it, primed and bled the filter, and primed again, still nothing. ive even loosened the union nuts on the injected while cranking it over to see if there is diesel getting to in - needless to say, i got diesel in my eye!
so yer, ive bled and primed the fuel....
#9 ·
Disconnect the low presure fuel line going into the high pressure pump - place the end into a container and prime the system until there are no signs of air.
Also try squezzing the primer bulb when the engine is cranking - this helps the fuel pump to self bleed.
WARNING - NEVER EVER - open a high pressure fuel line when the engine is cranking or running - any escaping pressurised fuel has enough force to kill.
