Megane - Sloshing noise
1 reading
10K views 11 replies 8 participants last post by  Jimmyb983
#1 · (Edited)
Former owner of a 1999 renault megane (I now drive an 07 Civic) but the car was passed on to my sister-in-law and is still very much a big part of my life.
Here to seek advice with an issue that doesn't seem to want to go away. About 6 months ago I booked the veicle in for a service and reported some water gushing noises coming from the passenger footwell, especially during heavy braking or accelerating. The garage identified the head gasket and waterpump as needing replacing, which (after a four figure fee) semed to solve the problem.
6 months later and we're hearing the same sounds again!
Its booked into a different Renault garage for them to take a look. The previous work should be gauranteed but if its something new I'm gonna be annoyed! Wondered if anyone around here has experienced similar problems..?
Thanks in advance.
#4 ·
Cheers chaps, useful reading.
The linked thread seems to identify issues with a leaky head gasket forcing water back through the system or water collecting under the dash due to blocked drain holes.
I suspect the car has now experienced both issues. Both issues probably sound very different 1st hand but sound similar when described. Since I experienced the first and sister in law experienced the second without cross-over we likely incorrectly assumed it was the same thing.
Anyways, she has investigated further and it seems its most likely water collecting in under the dash due to blocked drain holes. She isn't too handy herself so has dropped it into a Renault garage for them to clear it out.
Thanks a lot for the help :)
#5 ·
When the car is stationary and with a cold engine give it a good old prod on the accelerator. The sloshing noise will coincide with the engine revving if it is an air lock or HG problem, and will probably (hopefully!) make no sound if it is a drain blocked problem.
Bob
#6 ·
I have recently had this problem on my Megane Coupe 2000 reg. For a few weeks it has sounded as if there was water sloshing around the passenger footwell behind the glove box when accelerating and braking. Had a good look under the bonnet yesterday and couldn't see anywhere water could get trapped. I then remember a friend telling me water can get trapped in the sills. I got on the floor and had a look under the passenger side sills and just before the rear wheel arch starts there is a rubber grommet. I popped this out and about a gallon of water rushed out. I left it out all day while driving to drain completely.
Hope this helps anyone.
