Radio code input not displaying
18K views 5 replies 4 participants last post by  Danp7
Hi you need to leave your Radio & Ignition turned on while the message Error is being displayed, usually after maybe 30-60 minutes or so, the word Error will change back to CODE or 0000 after which make sure you input the code sequence correctly.
After a preset # of incorrect code inputs, the radio defaults on the Error message & the word Error remains on the screen for twice the prior amount of time, it's all part & parcel of the radio security system, this doubles up each time the code is incorrectly applied
Input Code
1. Switch on the radio and then 0000 will appear in the display screen.
2. Adjust the flashing digit with the thumb wheel on the steering wheel radio control.
3. Press the lower key on the steering wheel radio control to confirm the digit and move to the next one.
4. When complete press the lower key on the steering wheel control until you hear a bleep which should validate the code.
So if your code is 1232:
1. Turn the thumb wheel until you see 1 then press lower key.
2. Turn the thumb wheel until you see 2 then press lower key.
3. Turn the thumb wheel until you see 3 then press lower key.
4. Turn the thumb wheel until you see 2 then press lower key
5. Then press and hold the lower key on the steering wheel stalk until you hear a bleep.
The code is now entered and saved.
