Scenic warning beep and red light
11K views 8 replies 3 participants last post by  gary77
#1 ·
Hi all, coming down hill to a mini roundabout today and as i got half way round it heard to beeps and just saw a red light go out on dash, have not managed to repeat it by sharp steering right. anyone know what this was,just didn,t see the light long enough.its not fuel warning.two quite loud beeps regards DAVE
#2 ·
i had the same today , i could have swore it was the oil light , but did it again and was the handbreak light , not found out why yet , posably brake fluid , checking levels tomorrow. the stop light came on at the same time , but both went of seconds later
#4 ·
It did it again today on my way to work, 20 mins into the journey, hasn't done it since, drove the car about 30 miles after the light,
Brake fluid levels are ok, rear brake pads and discs look like they need replacing though
#5 ·
The beep is the car computer flagging up there's an uncleared fault code its found. Dealer will hook up the Renault diagnostic computer and clear it in a matter of minutes. if not cleared after a while it'll start to beep at you during engine start up procedure.
#7 ·
The computer records all faults even the minor ones that are not an immediate operating issue and keeps them in its memory. Then at dealer service downloads all the fault codes to the dealers computer so dealer knows what to fix and clears the memory. When the memory is full or a significant fault occurs and the dashboard stop light's come on it beeps too. If you've got the stop light coming on and off and the alarm going off too then I'd get the car to the dealer asap. There's an aftermarket gizmo u can buy to plug into the diagnostic socket under the centre console but you'll also need the fault code list to understand what the alphanumeric codes mean.
