Update on Auto door unlock*Fixed*
2.9K views 6 replies 4 participants last post by  ottoman
#1 ·
I would like some advice on a door unlock problem. The drivers side of the car ulocks as soon as I put my hand in the handle with the card in my pocket but the passengers side doesn't although I can lock it from this side. I have replaced the battery's and also the card still no luck though any idea's
#3 ·
Theres probably nothing wrong with the key card, I do not have the hands free with my card but the drivers door is the only one to unlock when I press the button on the card, if I press the button for more than 2 seconds all doors unlock.
Mine can be used to open all doors with one quick press if I wish by using the interior lock button to programme it.
Your drivers handbook will explain how to programme yours.
#5 · (Edited)
Hi winslo,
For some reason a previous owner of the car must have had it configured that way.
I believe only a Renault Dealer can reconfigure the system so as all doors unlock at once.
Tho there is an option in page 1.8 of the handbook " Using the Renault Card in restricted mode " whereby only the drivers door can be opened
#6 ·
Hi and thanks to all of you that replied to my thread last week. I have now had the problem diagnosed and it turned out to be the mechanism on the back door lock on the inside that was at fault. This also put out the front door as well. I have now had the problem repaired at a cost of £122 pounds and all is working ok again.
