Hi All I have kangoo 1.5di 88k miles, 2004 model.
When I try to start the engine, it struggles to start (Need to turn key 2-3 times for it to start properly). Once started, it can be turned off and started again however just struggles on the initial start.
The glowplug/electric light is illuminated all the time, no matter if it is starting or whislt driving, it doesn't turn off. I have been unable to successfully OBD read the car and assume I need a canclip or similar to check the diagnostic.
I have cleaned the EGR valve for the sake of it, and i am unsure what could be causing the problem of the light be on and the struggling start. The car does blow black smoke on start up, not much but is noticable after it has ran for 5 mins, the colour goes normal and stops smoking. - There seems to be some black carbon residue in the exhaust when accelerating (any advice?) i have only owned petrol before so not sure whatis norma and not normal for diesels.
The car has been fitted with lesuire battery with a smart relay to not drain the main battery, could this be causing the struggling start?
The car does seem to rattling around the EGR or the back of the airbox (Not sure what else is located there as i've not been able to see a diagram.)
The car has extensive service with the EGR looking almost pristine and brand new via to me removing it so seems vehicle has been well looked after.
What are peoples ideas or suggestions for the coil light on and what could be causing it? I am currently uninsured as this is sat on my drive being converted into a camper so all help without taking it to a garage to diagnose would be appreciated. Many thanks
