Please see below. Good luck!!!
Customer Question
I have a Renault Scenic 2 1.9dci 2004 model. Is it possible to remove the turbo charger without removing the engine? If yes, what step by step procedure should I follow?
Regards,
Joggie Lubbe
Country: South Africa
Make: Renault Scenic 2
Model: 1.9 dci
Year: 2004
Already Tried:
Got a quote (R 18 000.00) from Renault to replace the turbo unit complete with oil return pipe and gaskets. I do not have this kind of money available at this moment. I can have the turbo rebuild including all the gaskets and oil return pipe for R 5 900.00
Submitted: 395 days and 2 hours ago.
Category: UK Car
Value: R 370
Status: CLOSED
Expert:
Walt-mod replied 393 days and 20 hours ago.
I'm a moderator for this topic and I wonder whether you're still waiting for an answer. If you are, please let me know and I will do my best to find a Expert to assist you right away. If not, feel free to let me know and I will cancel this question for you. Thank you!
Customer replied 392 days and 23 hours ago.
Yes, I'm still waiting for the step by step dismantle and refitting of the turbo charger.
Accepted Answer
Expert:
Mike replied 391 days and 14 hours ago.
Hello and Welcome to justanswer..
Basically, this can be done , remove and replace , without removal of the engine - but you need the vehicle either on ramps - or over a pit.. you need to work from above and below - so you need to remove the under tray ...
Its really just a case then of working through - removing the fixing bolts / pipes etc - most of which are obvious - but the fittings / bolts are not so obvious so to help you - I will give you an exploded overview of the Renault turbo you have which shows all the fixings / bolts that you need to remove... so that will help you complete the job ( obviously refitting is a reversal of removal - and you can use the same diagram to help you make sure you have fitted all back again..
I think our one is going. My wife was driving when low
oil pressure poped up on the dash along with stop so she did. It cleared straight away but since then the
turbo is now making a noise and there is a noticable loss of power. She has managed to get it home fine and i will have to remove the
turbo extra to check it all.
12th October 2009
Well i started the job of taking the
turbo off this evening but before i started i turned the engine over and got a big clod of bluey white smoke out of the exhaust. I haven't got it full off as yet as it got dark and i was hungry but there is
oil in all the pipes i have taken off so far and the inlet for the
turbo looks like this.
I shall carry on tomorrow and remove it completly and see about gettting either it reconditioned or getting a replacement as i am hoping that we got it at the start of the
failer.
Apart from cleaning out all the pipework and intercooler what else should i be doing.
