I'm back. on what feels like a never ending saga with my daughter's 2002 clio 1.5dci.
I've already had responses to a previous post so thanks to all.
Initially the car stopped starting. i followed the threads and changed the glow plugs (broke 2 so head off and heli coiled). changed the flywheel sensor (no difference) then mullered the top end by missing the fact there's no crankshaft woodruf key (thanks Mr Renault!).
so... recon head, new glow plugs and sensor, piston rings, big ends, belts, filters and oil. all timed up with pins.
i've just turned the key and checked the compression (all around 400-420 psi).
glow plugs back in and after a few turns it idles nicely with no dash lights on and no codes on my code reader. I have probably mixed up the injectors (cleaned and checked professionally along with the pump) but was told the ecu would probably sort that one out itself.
now i come to press the accelerator and i might as well be treading on a radish! no response from the pedal at all - just a nice tickover.
please help if you can - there's nothing worse than a daughter losing faith in her Dad!
