@John J,
We did inspect the faulty actuator/adjuster and internally it's a PCB with a motor on it, give or take a few extra bits. Current was ok through the unit but the motor was burnt out and by the time we sourced a replacement motor (RS etc) and unsoldered/soldered/tested etc it would've been just as easier to get a whole new unit. We get trade discount from our dealer and also the VAT back so it's always a little cheaper than retail anyway
The Renault part number for the adjuster/actuator (sme on both sides) is 8200 277 945. This is for the Xenon Headlight adjuster only as they differ between Halogen and Xenon type headlights (connector and track location).
Hope the above helps and good luck whichever route you decide to take! Let us know how you get on
AdvancedPCs
Well I got the unit out & tried tightening the connectors etc but alas - no success.
Got a quote for £130 for a replacement so I guess that isn't trade pricing! I think I'll take the RS route.
I "guess" it is a stepper motor & a stepper motor controller on the board. £130 quid seems a bit steep for that! Any idea what the part number was for the motor so I can research before pulling out again? What made you think it had burnt out? - TIA
Zedster - with respect to headlamp height checking, you can simply check against a wall or garage door at night provided you have a level surface in front of it for about 10m. as follows;
1) Drive as close as you dare to a vertical object e.g. garage door.
2) Set the headlamps to main beam and mark the position the centre point of the light makes on the door (e.g. using sticky tape)
3) Reverse in a straight line about 10m from door ON A LEVEL FLAT SURFACE.
4) Under the bonnet (near the headlight) you will see a % figure indicating adjustment setting. On mine (Xenon) its set to 1%.
5) put another piece of tape on the door 10m x 1% i.e. 10cm below the original tape.
6) check the max intensity of the light spot on the door is at the level of the lower piece of tape.
The 1% figure seems lower than previous cars I've owned but I guess thats because they self adjust for the driver when they get in, compensation that clearly doesn't happen on non-adjusting units. Non-Xenon units presumaly have a different figure? Anyone care to comment?
This process has worked for me in the past & enabled be to successfully adjust my non-Xenon headlights to get through the MoT. Not the simplest, but it works.
JJ
