Trafic clutch adjustment
21K views 14 replies 8 participants last post by  Renoir White
#1 ·
hi all
i have looked on this site a lot about info on my clutch, but could not find much on weather it has an adjustable clutch or not, and how to adjust it
i have read quite a bit about high clutchs on the renaults, mine is deff right at the top, and if i shift from 1st to 2nd and let the clutch out quick it makes a little squeel but not really a slip if that makes sense
thanks in advanced for any help
#2 ·
I don't know for sure but I doubt very much it will be adjustable,
haven't seen a adjustable clutch on a car or light van for many years.
#3 · (Edited)
I believe the clutch is 100% cable operated and there is the usual type of adjuster one end of the cable. There's no self-adjusting ratchet that I'm aware of. I'm not sure how much free-play there should be at the pedal but old-skool guesstimates were to have about 1/2" freeplay if in doubt.
Eddie had fitted a new clutch to Snowball so perhaps he might have some recollection.
If I start my van tomorrow I'll see where my biting point is.
If the clutch isn't slipping the squeal could be from the thrust bearing. If it isn't too loud and soon goes I wouldn't worry too much for now. Maybe the van needs a few miles on the road to get everything freed up if its been standing a while.
  • Like
Reactions: HEIDI 2002
#4 ·
I'd suspect the squeal to be something like an engine mount not liking the jerk.
Or possibly a tiny bit of wheel spin.
RW could be right on thrust bearing.
To test for clutch slip, one way is find a hill that the beast will climb in third without too much protest.
Then put boot down.
If revs climb without speed, clutch is slipping.
If engine labours and thinks on stalling, clutch is fine.
Assuming RW is right and it is adjustable, putting your foot under the pedal and lifting will show free play..there should be some.
If there isn't, will need adjusting to get some.
If it is a self adjuster, at that age, similar trick will often force the adjuster.
#5 ·
hi both
the van has been sitting for a little while a few months, and sound not too loud only lasts for a second, so hopefully it will work out ok, also have tried the hill thing just and it holds with no sign of revving up
have put foot under pedal and there is no free play at all will not budge a mm, so again hopefully good news by the sounds of it
thanks both for the tips it has put my mind a rest a little and hopefully the squeel will disappear soon :grin2:
#6 ·
Doesn't sound like clutch slip if no rev increase under load.
But if clutch is adjustable, there should be some free play, lift on pedal.
Same with older style self adjusts.
I don't know what you have but I would be still looking for a definite answer.
The concern is that if the adjustment system is holding the clutch even fractionally, there may be no slip now but soon will be.
#7 ·
If it's like mine there should be a couple of nuts on the gearbox end of the cable. If you take off the heater intake (two clips) and look down it's there. Can't find it now, but I think the free play is supposed to be something like a few mm at the gearbox end. If you push the lever away from you and pull the end of the cable with all your might, there should be a bit of a gap.
#12 ·
Ralph see reply to RW but there is one adjustment to be made to clearance 10mm I think on the clutch cable Mind to be honest I didn't quite get it right my van snatched between fifth and fifth gears on the way up and third second on the way down
#13 ·
Info of the Trafic 2.1D engine and transmissions may be found here: http://www.lesharo.co.uk/Winnebago.....................................
Please read the rules to which you agreed, about links to copyright material. Thank You
NOTE: I always recommend a LUK clutch as a replacement and always replace the throw-out bearing at the same time. The OEM clutch plate assembly is usually a Meyle. Valeo also carries them.
