firing order on clio 172 2001
19K views 6 replies 4 participants last post by  OzRX4
#1 ·
hi can anybody help me, my cars not firing right and i need to no the firing order on both the engine and coil pak thanx, pic wud be appreciated if you can
kieran
#5 ·
Hi sween, the Clio has 4 seperate coils, one on each spark plug. Remove the engine plastic cover and you'll see the 4 ECU wires to each coil in between the inlet tracts. There's a small clip on the lead, hold it fimlry and you'll feel it undo then pull towards you.
WHat's the issue? Just changing plugs or coils?
