Leaking windscreen seal - Clio mk11
5 reading
3.1K views 1 reply 2 participants last post by  Renoir White
#1 ·
Sorry but am not very good with the technical jargon but the seals around my windscreen are leaking. The horizontal seal at the top of windscreen looks like it has shifted along from right to left so there is now a gap and the corner trims are poking up.
I was going to try and fix this with silicone and super glue.
Does anyone have any tips on how to do this or any orher ideas?
Thanks very much
#2 ·
I've never tried anything with a bonded windscreen but in the past when I have tried various auto sealants on rubber seals none of them has worked satisfactorily and water has still seeped through. I would recommend you get a windscreen fitter to refit the screen for you. It shouldn't cost much if they can remove the screen safely.
