Hey Guys, don't know if this has ever been posted before, but with it being winter now and I'll bet many of you are constantly washing your windscreen to get the grit dirt off from the road!
Recently I had a problem which seemed like a blockage with my windscreen washer pump - It started to go weak and then I got nothing what so ever out of the jets, even though I could hear the pump running!
So out came the screwdrivers and spanners!
(Still with me!!!!)
Basically - Once I had got to the motor and taken it out I tried to look how to disassemble it (It is Possible)
1) The section with the long shaft which goes into the washer bottle can be separated by using a large-ish screwdriver by inserting it into where you can see the gap and twisting the screwdriver - It is clipped on with a little lug too - so look out for that!
2) You will see the black and white plastic "Valves" where the pipes come out from - These too need removing from the pump using the same screwdriver method.
-Then-
3) Then the black and white parts need separating in half to expose the valve bung - You should be able to see the retaining lug, which needs a small screwdriver to lift the plastic over the lug - Then the black and white parts separate. (With force!)
Inside you will see a small silver plastic "Valve" which SHOULD move from side to side to block the opposite pipe that is not in use when the pump is running.....
This was the problem with my pump - The rubber within the silver plastic had expanded to the point where it was permanently blocking both pipes.
Basically I took a sliver of the rubber off each side using a craft knife so that the "Bung" could move freely when I blew through the pipe to test it, Then clipped it back together fully and made sure it wasn't blocking the holes when it was back together.
When it was all back together and working my jets shot over the roof of my car! Duly Re-Adjusted with pin!
Rough Diagram attached!!!!
:d:d:d
Hope This solves a few problems this winter!!!
(Still with me!!!!)
-Then-
:d:d:d
