61 - 70 of 70 Posts
Hi Joeishmather,
I've just bought a Megane 3 (2011) its been suggested the wiring to add cruise may be already in place, any idea if that could be right?
The switch sits in the handbrake console, mine has a blank fitted and the controls are on the steering wheel.
Am I being somewhat naive in hoping that I could simply fit the switch and change the steering wheel, make the connections, if the wiring is in place, and job done??
This seems to be the only thread I can find regarding retro fitting CC, although its an old thread.
Many thanks,
Mart
Im rather confused as to which bits exactly i need..
Im okay with the cutting and soldering and gluing etc, but i cant get to grips with which wires to select and where they go to... could you tell me the part numbers ill need to do it using a stereo controller like is already behind the wheel?
Hello. I apologize for bad English.I Have Renault Megane 2 dci 1.5 101 hp.I want to ask you to install cruise control.My car is missing the white connector which is shown in the image.In this case you can do something?
It works on the espace I try to put on some pics and how to as soon as I get chance
Sent from my HTC One X using Tapatalk
Hello,
Can you give me more details about the connections under the steering wheel?
I don't find the previous pictured connectors on my 2002 Espace 1.9dci
Can you give me more details?
Many thanks
Seb
I found the wires where the switches have to be connected
After removing the covers behind the steering wheel, on the upper/middle zone will find the pictured connector
This connector have 6 wires
4 wires on the down side of connector, there are for the airbag
And 2 wires (grey and white) on the upper/right side of connector (positions are regarding driver's normal place)
These two wire will be used to connect the +/-/R/O switches, like previously described in this topic
I hope the picture will clarify better than my explanation. Sorry, I'm not a native English speaker.
This is working on my 2002 Espace 1.9dCI and I cannot tell you for sure will be the same on other Espaces
Regards,
Seb
Hi, I have a Megane 2 cabrilet 1.9 dci, I'm looking to fit cruise control. I igot the steering wheel with all the buttons, can you advise me on how to wire it in to the loom. Barry
61 - 70 of 70 Posts
You have insufficient privileges to reply here.
