Clio hub cap removal
23K views 6 replies 4 participants last post by  madnoel10
#1 ·
Hi folks, the wife has loss her tool for removing the screw from the hub caps on her alloys, its the three pronged one, now I have seen there are different types of these is there any way I can tell which one she needs from just the screws?
Thanks for any help you can give.
#2 ·
I think you would need to test-fit the relevant keys, as it won't be stamped on the bolt (which would be too corroded to read anyhow).
A couple of thin-nosed pliers (or at least one, used with a thin screwdriver) might be useful in unwinding the bolt.
HTH
Paul
